contact us
Use the form on the right to contact us.
You can edit the text in this area, and change where the contact form on the right submits to, by entering edit mode using the modes on the bottom right.
Melbourne, VIC, 3004
Australia
Detailed reviews and information of the best solar panels, inverters and batteries. Plus hybrid and off-grid solar system reviews and information articles on how solar and battery systems work.
Blog
Reviews and information on the best Solar panels, inverters and batteries from SMA, Fronius, SunPower, SolaX, Q Cells, Trina, Jinko, Selectronic, Tesla Powerwall, ABB. Plus hybrid inverters, battery sizing, Lithium-ion and lead-acid batteries, off-grid and on-grid power systems.
2. Complete hybrid systems with built-in battery storage
Complete hybrid systems with integrated energy storage are very simple to install and offer an attractive solution which eliminates the need to select and match individual components. These systems generally combine a battery inverter/charger, solar inverter, battery modules and energy managements system in one unit or 2 separate modules. All available systems at this stage use lithium-ion batteries but only the Fronius, Alpha and TrinaBESS systems are upgradable to enable future expansion.
These all-in-one systems may be very convenient but they do have some limitations, the main being the limited inverter power output during a blackout and no pass-through power capability. This mean your home may require separation of essential and non-essential loads. Also be aware that some of these systems (Samsung) have no UPS function so no power is available during a blackout, although if grid outages are very rare then this may not be an issue.
The following list explains in detail the features and specifications of the various hybrid systems available. Also see the full hybrid inverter and energy storage system summary list here for easy direct comparison.
Solax X-Box
Suntellite Group headquarters is located in Zhejiang University with two major manufacturing plants, 14 laboratories and five engineering research and technology centers throughout China. SolaX Power a subsidiary of the Suntellite Group manufacturers solar cells, panels, inverters, solar racking and LED lighting technology.
Solax Box hybrid battery system review
Basic specifications (2 sizes available)
  • Type: Complete hybrid system with built-in battery storage
  • Use: Self-use, Back-up (UPS)
  • Solar Array Size (Solar input): 3.3kW, 5.0kW
  • Rated power output: 2.0kW, 4.0kW
  • Peak power output: 3.0kW, 6.0kW (10 sec)
  • Pass through power: 63A in standby mode
  • Battery type and capacity: Lithium LFP, up to 14.4kWh
  • Battery System Voltage: 48V
See full specifications here - SolaxBox
Features
  • Attractive all-in-one system with simple installation
  • Large 7" touch screen display
  • Available in Single and 3-phase
  • Battery life of 4000 cycles at 80% DOD (claimed)
Note
  • Must be installed indoors (IP20 rated)
  • Peak power output 1.5 x rated output for 10sec.
  • Uses the well known Pylon Tech lithium LFP batteries.
Price bracket – Medium
Fronius Symo Hybrid
Fronius International is an Austrian company which began in 1945 designing and building welders. Fronius is now highly active in solar photovoltaics and battery charging technology.  Fronius and Tesla partnered to offer the Powerwall 1 in combination with the Fronius Symo Hybrid inverter as an integrated solution for residential PV systems. Since the Powerwall 1 is now discontinued the system is only compatible with the Fronius solar battery.
Basic specifications:  (3 sizes available)
  • Type: Complete system with built-in battery storage
  • Use (3-phase only): Self-use, Back-up (UPS)
  • Solar Array Size (Solar input): 5.0kW, 6.5kW, 8.0kW
  • Power output (continuous): 3.0kW, 4.0kW, 5.0kW
  • Peak power output: dependent on battery size used
  • Pass through power: None
  • Battery type and capacity: Fronius Battery: Lithium (LFP), 4.5kWh – 12kWh
  • Battery System Voltage: 48V or HV 400V
See Full specifications here - Fronius Symo Hybrid
Features
  • All-in-one unit - plus batteries
  • 3-phase inverter
  • DC coupling of storage
  • Long battery life - 8000 charging cycles at 80% DOD (claimed)
  • Inverter with IP65 protection (weather rated for outdoor installation)
Note
  • 3-phase inverter only - single phase to be released late 2018?
  • back-up power enabled via "emergency power button"
  • Phase loads need to be balanced - limited applications.
  • Battery must be installed indoors (IP20 rated)
Price bracket – Medium/High
Sonnen Sonnenbatterie ECO
Note: AC battery system requires additional solar inverter
Sonnen is successful German company founded in 2010. Previously known as Sonnenbatterie, Sonnen has become a leader in developing high quality, modular energy storage systems for residential and commercial applications and is planning to build a new battery manufacturing plant in South Australia.
Basic specifications: (Modular AC battery system)
  • Type: AC Battery system - Lithium LFP
  • Use: Solar self-use and emergency back-up power
  • Power output: 3.3kW (3.3kW peak)
  • Battery System Voltage: N/A (AC battery)
  • Battery type & size: Lithium LFP (LiFePO4) - 5kWh to 15kWh (2.5Wh modules)
  • Usable capacity: 90%
Features
  • Attractive, modular system
  • Premium Sony LFP lithium battery cells
  • Expandable storage up to 15kWh
  • Sophisticated monitoring system
  • Very high cycle life (claimed 10,000 cycles)
  • 10 year warranty
Note
  • AC battery - requires an additional solar inverter to be AC coupled.
  • Relatively low inverter power output 3.3kW
  • Low weather rating (IP20) must be installed indoors
  • Limited Back-up functionality (1.8kW)
  • Warranty - 10 years
Price bracket – Approx AU$1120 per kWh
TrinaBESS Powercube DC
See the complete detailed TrinaBESS Review here
TrinaBESS or 'Trina Battery Energy Storage Systems' is the battery company under the global panel manufacturing giant Trina Solar. TrinaBess supply a large range of solar hybrid and retrofit battery solutions for on-grid, off-grid, residential, commercial and micro-grid energy storage systems, from 4 kWh capacity up to a massive 2 MWh capacity.
  • Type: Modular hybrid system with separate battery storage
  • Solar Array Size (Solar input): 5.0kW (max 7.0kW oversize)
  • Rated power output: 5.0kW (2.4kW in backup mode)
  • Battery type and size: Lithium NCA - 2.4kWh to 9.6kWh (2.4kWh modules)
Features
  • Can operate and charge from solar in back-up mode
  • 5.0kW solar inverter with up to 7kW max solar array size.
  • Includes energy meter
  • Includes battery support pedestal bracket
  • Good cloud monitoring software
  • Warranty - 5 years inverter, 10 years battery
Note
  • Not a UPS (1-2 sec delay)
  • Inverter not weather rated ( IP21 )
  • Max backup power 2.4kW
  • No parallel capability yet
DC version Cloud monitoring – www.cloud.trinabess.com
TrinaBESS Powercube AC
See the complete detailed TrinaBESS review here
  • Type: AC Battery system - Lithium NMC
  • Use: Retrofit - Solar self-use and back-up power
  • Power output: Max 5.4kVA (for 2sec) output with grid active
  • Battery type & size: Lithium NCA - 2.4kWh to 9.6kWh (2.4kWh modules)
  • Usable capacity: 90% (assumed capacity is 2.2kWh per module)
Features
  • Easy retrofit to any existing solar system
  • Modular system with 2.4kWh PylonTech batteries
  • Max 4.8kVA surge in backup mode
  • IP65 inverter and IP55 battery
Note
  • Not technically a complete system - requires an additional solar inverter to be AC coupled.
  • Not a true UPS (up to 5 sec delay)
  • Cannot charge from solar in back-up mode
  • Outdated looking third party app monitoring
Alpha ESS Storion series
AlphaESS based in Jiangsu, China, have been developing economical energy storage solutions since 2012 and have distributed products in European and Australian markets. The latest is an integrated smart energy management system including hybrid inverter and battery modules in one complete unit.
  • Use: self-use, (UPS) backup
  • Solar Array Size (Solar input): 4.5kW-7.5kW
  • Sizes available (power output): 3.0kW, 4.6kW, 5.0kW
  • Compatible Battery types: lithium-ion modules, 5kW-19.2kWh
See full specifications here: Alpha ESS Storion series
Features:
  • All-in-one unit including, inverter, batteries and system management.
  • Simple installation
  • Many different options available in the Storion series
  • App monitoring and advanced communications (cloud monitoring)
  • IP65 weather rated for outdoor use.
Note:
  • Additional battery storage also available (expandable)
  • No additional pass through power
  • Built on the well known Goodwe hybrid arcitecture.
  • Back-up EPS is optional
Price bracket – Low/Medium
PowerLegato
AU Optronics (AUO) is an international company with global operations spreading across Taiwan, China, Japan, Singapore, South Korea, USA, and Europe. AUO's solar business has been adopting BenQ Solar as its brand name to offer high efficiency, reliable solar products that are easy to install.
  • Solar Array Size (Solar input): 2.7kW, 4.5kW
  • Power output: 2kW, 3kW (peak output 3kW, 4.5kW)
  • Compatible Battery types: Integrated lithium-ion
Features:
  • All-in-one unit including solar inverter, batteries and system management.
  • Compact unit
  • Long battery life
Note:
  • Low surge power capability
For direct comparison of all inverters & systems see the complete Hybrid Systems and Inverters Summary page.
